efinque
- Joined
- Jan 3, 2018
- Messages
- 350
Hello GroupDIY,
and excuse me for being new here.
Anyway, I've been dreaming of making a rotary DJ mixer for about 10 years now. I've searched the web and doodled a bit on paper but I came here asking for some additional advice.
As for some background ; I've been DJing since 2006 and played my first gig in 2007. I've owned and used several mixers over the course of years as well as serviced and repaired them so I have some knowledge on how they work. (edit : basically the design is something along the lines of Bozak/Urei and the boutique stuff like E&S)
Here's the initial sketch of how it would look :
(edit : the width is the standard 19")
Basically, I'd build the preamps from kits as modules with wiring as well as the (optional) isolator and level meter and the headphone amplifier.
For potentiometers I was thinking ALPS 50K stereo log and Alpha 100K dual log for trim controls. (edit : then there are Bourns pots also which are excellent from what I've read) As for the cue it'd be a rotary switch.
I found a 3-way linear phase filter/isolator kit from Analog Metric
I'm a little concerned about the PSU... I've been looking at one that's specs state 30VA, 230V AC / 18V + 18V / 0.833A + 0.833A but I don't know if it packs enough punch to power the whole thing (preamps/headphone amp + isolator)
Another thing is balanced outputs...
What are your thoughts?
-ef
EDIT : as for the isolator it'd be post-master (possibly bypassable)
EDIT 2 : I was also thinking Sifam VU meters but they're pricey albeit very classy looking.
EDIT 3 : Sorry I missed the headphone level control and cue. Updated
EDIT 4 : as some of you might have noticed I'm obsessed with disco stuff.. I've been designing and building a classic dance stack (the "finished" stack is on page 11 but I haven't worked on it since apart from making a driver hole in one of the scoops)
EDIT 5 : Stuff I already have/can make use of : soldering iron, multimeter, a bit of free time... I also have an Arduino Uno board and some components too. Financially speaking it wouldn't be a big deal I guess, back in high school when I had the idea I didn't have any resources to begin with... now there's a slight chance of making one.
EDIT 6 : Sorry for the messy picture but I hope you get the idea.
EDIT 7 : I've also been scheming a studio mixer on Arduino forums.. I guess it'd be better to start from a project of this scale.
EDIT 8 : I'm not an avid DIY-er when it comes to electronics.. I built a radio back in school but that's about it. I did pull a headphone amp from a Presonus FP10 audio interface to my Mackie D4 because I broke a plug inside the connector and couldn't get it out in one piece without damaging the terminal... it works like a charm. I've also been thinking of servicing my Formula Sound PM-90... I asked the company for spares and the costs would've been astronomical, and seeing the mixer was installed at a venue back then I postponed it..
EDIT 9 : I'd guess some would prefer pan controls instead of gain.. which is something I've also considered as it is a rotary. One thing I didn't consider was a cue/pgm switch.
-ef
