efinque
- Joined
- Jan 3, 2018
- Messages
- 367
KrIVIUM2323 said:I don t know specifically of the mixer you are talking about or their functionnality but an aux and an insert are different things, this is independant from the level at which they work.
An aux is a parallel feed with an indepandant return which is mixed back to a bus. It usually have volume controls (individual sends, master sends then a fader to mix in the receiving buss).
An insert is a series feed, without volume controls as the reference levels is predetermined (pro or semipro line level or anything that please you) and it just need a on/off switch to be activated.
In your overall layout your isolator is in serie between your mix bus and your main output card, no need for an aux.
Same thing in your chanel if you want to include some processing in individual chanels.
An aux is interesting for external effects (mainly time related like reverbs, delay, chorus,... you name it) can sometimes be used as more output or to make parralel treatment but i doubt you ll use them like this.
I've been lately using the channel sends from my Mackie D4 to a Macbook Pro running an instance of Traktor and Reaktor software in a live setup (you can check the in-depth article on the setup in my blog)
The send feeds a subharmonic synthesizer (edit : I programmed it a while ago, here's the thread on NI forum) which tracks frequencies from the program material and turns them into MIDI notes which are then again fed to a drum machine which has a built-in analog synthesizer which goes to a channel on the mixer.
EDIT : This basically allows me to blend basslines too... I can bring up a synthesized bassline and choose not to send the synth the track that's playing, basically blending the synthesized basslines on the fly..
EDIT 2 : as for the VU meters; I have an old JVC KD-A11 tape deck with sweet looking analog meters.. however I cleaned the playheads and calibrated it not too long ago (I use it for tape saturation) so I can't really justify using it as spare parts
