efinque
- Joined
- Jan 3, 2018
- Messages
- 367
user 37518 said:Another dirt cheap opamp is the LM301, which in my opinion is a very interesting part, I´ve seen Studer designs in which they replaced the entire input section of the 301 with discrete circuitry, it seems however that it is mostly frowned upon for modern work, the national semiconductor application handbook is full of 301/101s, it is my favorite opamp to use as a comparator thou, if im not using a lm311 /339
If by Studer you mean their tape recorders; I think you'll be lucky to find one in a studio these days.
I have a Philips EL3556A (mono) tape recorder which I serviced and it seems to work but I have no reels or tape for it. Fancy machine as it uses a tube. However, most professional applications would require a faster machine (this one goes 19/7,5ips)
