Hi there!
I got some questions about transformers, especially the Carnhill.
I got some spareVTB 2280 transformers, 600/600, 1+1:1+1.
Can I use them as substitutes of VTB1148? If I read the datasheet:
VTB1148: 1+1:1.7+1.7, wired in serie primary secondary (like 1073 output) the ratio is 200/600 with +4dB gain
VTB2280: 1+1:1+1, if wired parallel primary and serie secondary, the ratio is 150/600 with 6dB gain
If I use them in 1073 clone or 2254 for example, the only difference will be the gain output? (2dB)
Xformers are sometimes obscurs for me... I know the output Z reflects the input Z...
Take a look on VTB 9045, used as interstage in 2254, wired serie/serie, 1+1:2+2. Can I use a 2280 here?
VTB9046, used as input in 2254, serie/serie, 2+2:1+1.... Can I use a 2280 revrsed here?
I know you can't swap output xformer with input xformer because of bias current, but what about swapping input with output?
Thanks for help
Thanks for help
