Re: D-47 Tube Mic Kit DIY Solution
« Reply #40 on: March 20, 2018, 09:33:24 AM »
I'd love to be in for one kit on the next batch, if they aren't all spoken for.
Pmed,
best,
Dan,
« Reply #41 on: April 03, 2018, 10:38:16 AM »
Dan,
I'd be up for two in the next batch, if there is space please.
Thx
Mark
vinylwall
« Reply #43 on: April 10, 2018, 04:02:33 PM »
FLEA 48 with Dany's D47 headbasket assembly - perfect fit and works great:
« Last Edit: April 10, 2018, 04:09:43 PM by vinylwall »
Jimi Ray
vinylwall
« Reply #44 on: April 10, 2018, 04:04:03 PM »
Dany's D47 body assembly with a genuine Neumann U47 headbasket (serial #5084) - perfect fit and sounds great:
« Last Edit: April 10, 2018, 04:09:57 PM by vinylwall »
Jimi Ray
vinylwall
« Reply #45 on: April 10, 2018, 04:07:22 PM »
Fabulous job on this kit Dany!!!!  It was a joy to build and it sounds AMAZING.  I built the VF14 style kit.  I have a new Telefunken VF14K as well as a vintage VF14 (non-M).  With the Theirsch Red-line (mylar) capsule and AMI's BV08C Classic transformer.
Here is a folder full of pics of my build:
http://www.vinylwall.com/D-47VintageBouchard/
« Last Edit: April 10, 2018, 04:30:17 PM by vinylwall »
Jimi Ray
lkipod
« Reply #46 on: April 12, 2018, 12:51:25 PM »
Mine is ready also with Phaedrus vf14m
How does it sound?
Any annoying noise problems?
Moshe
TLRT
« Reply #47 on: April 12, 2018, 01:05:15 PM »
How does it sound?
Moshe
Hi, No noise problems, it sounds great! Use proper star-grounding in the PSU and join 0V and screen to the mic body.
« Reply #48 on: May 17, 2018, 01:36:55 PM »
I'd love to order one of these when they are available again
tommypiper
« Reply #50 on: May 19, 2018, 08:39:45 PM »
Looks very interesting.   8)
For the VF-12 / 14s, what transformers are currently available?  Is AMI still making theirs?
Imagine a wet, slightly chilled from its gas release and decompression, with water droplets condensing, sucking surface tension, slowly sliding down the side, capped by a healthy virgin froth on top..
« Reply #51 on: May 20, 2018, 04:59:09 AM »
I'd be up for one!!!!!
« Reply #53 on: May 20, 2018, 07:30:50 PM »
yes they are but there is other option too the AMI BV8 classic if very popular  , i have three different PCB that supports alot of different transfomer as well,  haufffe,cinemag , and others ....
 best,
Dan,
« Reply #54 on: August 29, 2018, 02:42:28 PM »
hi Folks , for those who are building the mic , i have found that putting a small dab of epoxy on the contact tongue inside the headbakset eliminates a resonnance cause by it , as it might be confused with an Mbira instrument from africa,
also using a little dab of epoxy on the screw thats hold the tongue will prevent any shifting during years of operation ,
I am almost ready to release the third batch , i have prepared a little temporary webpage to checkout the offered options,
http://www.vintagemicrophonepcbkit.com/OrderD47.html
Dan,
JessJackson
« Reply #55 on: September 02, 2018, 01:55:34 PM »
havnt visited this forum in a minute but WELL DONE bro. Looking sweet!
« Reply #56 on: September 05, 2018, 01:57:18 PM »
yes i have done it the last minute you were off  this site ,
BEst,
dAn,
« Reply #57 on: November 15, 2018, 02:13:28 PM »
Mechanical Mic  kits are back in stock, :)
Matt Head Style is Now Available Limited Qty initial run
D47 Mechanical Kit
For the First Time U48 is also available in limited Qty initial run
U48 Mechanical Kit
Best
Dan :)
vinylwall
« Reply #58 on: November 15, 2018, 02:22:56 PM »
Dany, you make the most beautiful kits out there!  Second to none.
Jimi Ray
rockinrob86
« Reply #59 on: February 08, 2019, 10:56:07 AM »
If I built an EF47 kit, with the power supply, would I be able to use that power supply with the EF version of this?  I am wondering about the pattern switching, since this has it on the microphone
Last post July 01, 2005, 04:18:32 PM
by
Last post July 01, 2006, 10:43:54 AM
by malkjos
Last post October 03, 2007, 02:29:18 PM
by rattleyour
Last post September 16, 2018, 04:20:49 PM
by TillM
