john12ax7
D/A converter schematics
« on: January 20, 2018, 07:23:25 PM »
I've looked around but haven't found much,  looking for some audio converter schematics to study.
Looking to build some D/As. I would think something like an AES receiver chip with clock recovery, that feeds a dac and then an analog I/V stage.  How does the receiver attenuate the jitter? Do you still need a clean PLL and crystal in this case? I would think you still need a clean reference.
Any schematics or relevant part numbers would be appreciated,  especially for the receiver and clocking part.
ruairioflaherty
Re: D/A converter schematics
« Reply #1 on: January 20, 2018, 11:01:54 PM »
Hey John,
When I was trying to wrap my head around converter topologies I found looking at manufacturer Evaluation boards to be really helpful.  They are usually fairly lean designs but high performance.
Many of the state of the art converters are using a local oscillator and reclocking the input, the Benchmark DAC 2 and 3 and good examples.
I like this white paper from Ian Dennis at Prism Sound
http://www.prismsound.com/test_measure/support_subs/resource.php?rid=173
And some slides from a presentation he gave that are related
http://www.aes-media.org/sections/uk/Conf2011/Presentation_PDFs/02%20-%20Ian%20Dennis%20-%20Performance%20challenges%20in%20audio%20converter%20design.pdf
john12ax7
« Reply #2 on: January 21, 2018, 02:20:27 AM »
Thanks, I will take a look at those.
ruairioflaherty
« Reply #4 on: January 31, 2018, 10:50:52 PM »
Another resource for DAC development is NWAVguy's blog
Here's a relevant page but you can search through the blog history for more posts.
http://nwavguy.blogspot.com/2012/04/odac-released.html
For those in the know there will be nothing earth shattering here but it's fun reading to gain an insight into some of the design challenges in building a DAC
Rochey
« Reply #5 on: May 15, 2018, 01:49:17 PM »
Might I suggest you start with something simple and get some quick success, before aiming for the moon?
I'm incredibly biased (this was my part when I was at TI - I defined it to be a simple, easy to design-in, high performance DAC), but just try doing a schematic and layout for a DIR9001 + PCM5102A setup.
It'll give you 112dB SNR, and support up to 96kHz, but the design is very forgiving and easy to make.
I'd also hook up all the IO pins to an Arduino so that you can reconfigure the part easily.
Rochey
Expat Audio Home: http://www.expataudio.com
pucho812
« Reply #6 on: July 18, 2018, 08:19:31 PM »
This is interesting.  I would love to see some a/d designs as well
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
scott2000
Re: CD4046BE in place of HCF4046BE
« Reply #7 on: September 18, 2018, 02:17:29 PM »
Off topic but is there a problem using a CD4046BE
http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=cd4046b&fileType=pdf
 in place of an older HCF4046BE??
https://www.datasheets360.com/pdf/-4647636057384631808
The HCF are hard to source and I need a replacement for an old converter....... Just want to make sure...
Thanks!!!
JohnRoberts
« Reply #8 on: September 18, 2018, 02:21:50 PM »
if the specs all line up. just do it...
Don't only half-ass tune your drums. Visit https://circularscience.com to hear what properly "cleared" drums sound like.
scott2000
« Reply #9 on: September 18, 2018, 02:42:52 PM »
Thanks! Yeah the main parameters are exact as are many of them but, the phase comparator (sp?)  specs are confusing.... I'll need to sit down with them and section them out where I can better understand the differences. May just be the sheet layout... Was being lazy and hoping someone would have already had some experience with any differences if any.
I know some synth building sites mention some types of 4046 not working well in some circuits but I didn't look into if it was just a manufacturer complaint or related to specs...
