Theoretical exercise here.
Glancing at the specs walked through at this link, concerning comparative sensitivity of the 87A versus the 87AI:
http://repforums.prosoundweb.com/index.php/topic,36194.msg531542.html#msg531542
It looks like U87AI single backplate is 8.4dB more sensitive than the U87 dual backplate.
47V polarization versus 60V is a -2.1dB sensitivity difference. Therefore a U87AI run at 47V versus 60V would be 2.1dB less sensitive.
Following from that, 23.5V polarization would be a 6dB sensitivity reduction, which with a single backplate is still just barely higher than the original U87, so it comes out in the wash. What else changes with response and distortion? What does such low polarization sound like? How does one best create a voltage divider to attain both 47V and 23.5V?
For those not adding all this up yet, it's a possible (bad) path to getting all three patterns out of a single backplate capsule in a U87 build. Better would be to come up with either a 94V or -47V bias for figure 8.
