Ok , this is where we start at BeeBird.Check pdf.
Also here is picture of 1084(almost done) that we made for one forum member.
Wiring of 1084 is not an easy job , but not to hard if you put everything in its place.Dual concentric to edge connectors are hardest part.
You have two way of making this.First solder wire to switches , and then to edge connectors , and we take that way at the beginning of our firsts 1073 , but now we do that opposite .First edge connectors ,why? because that place can end as a ridiculous mess of wires and capacitors.Nice workflow can be if you start with , ground and +24 wires and those big 470uf capacitors , and then slowly add a rest.Remember +24 on wrong place can f..k up your precious 10486.So check that part more than once .
Dont go to crazy with original 1084 one on one replication .Spotting NOS mustards and other 70ties era parts can be PITA those days.You have lots of great parts today.Yellow axial Vishay are very nice , and I advise you to put in quality el capacitors.Lots of benefits for small amount of added funds.
