FET/Rack REV A& D Input/Output Knob Installation
JDport
New member
Greetings builders,
Just finished building a FET/Rack Rev A & D. When installing the "Input" & "Output" control knobs, where do you set them?
If they are set full CCW, and snugged down and 6 o'clock them the min value is at 6 o'clock ( and the max value is 6 (doesn't go to "0").  If set at min value of 8 then my max value is 3 (doesn't go to "0"). Please advise.
Thank you guys,
JD
This is just the way it is - set them in what ever way makes you feel better and never look back.  :)
It's gratifying when the scale matches the turn radius around the knob, but  it doesn't in this case.
