417A + 2A3 preamp schematics
reellike
New member
Hi
I want to DIY a preamp ( 2A3 tube)
I want to know the schematic of the peramp can work or not?
Any suggestions to me
Thank you !
Choice of preamp tubes is strange, you could get away with expensive gapped coupling transformers and use caps or DC coupling instead.
For 805 amp you could use DC connected two halfs of 6SN7 into 805, then gapped output transformer. Using power tubes as drivers isn't best practice because of very low gain.
reellike said:
Hi
Thank you !
404 error message on all the attachments..
