Light Beam Meters - Neumann PTMV
Gold
Brooklyn
I have a set of light beam PPM meters in a Neumann SP66 mastering console. I had another set in previous MT66 which is almost the same as an SP66. I could never get them calibrated where I trusted them.
I recently discovered a Neumann factory calibration procedure for the PTMV amplifiers. I also found a calibration procedure for the meter unit. I’m having someone restore them. The PTMV has nuvistors and that is out of my wheelhouse.
I can’t wait to see a properly calibrated light beam meter. I’ve never seen one before. I don’t imagine anyone under say 60 years old has ever seen a properly calibrated one.
The first time I saw anything like that was in the physics lab at secondary school in the 60s. We had a couple of light beam galvanometers for measuring tiny current. They were about the size of a dinner plate. Saw one or two Neumanns  in studios around London in the 70s but they disappeared soon after.
Timjag said:
I'm naive - what's a lightbeam meter?
It is like a regular edgewise meter except the needle is replaced by a small mirror. You shine a beam of light at the mirror and shine the reflection on the meter dial. As the meter operates, the mirror is deflected and with it the beam of light. And you get a 2 times optical amplification for free.
Here are some photos.
You can see the front panel calibration. Set 0% then set 100%. Then move into operation mode.
These are the PTMV amplifiers. You can see four trimmers in there. Mysterious.
This is the rear. You can see the nuvistors on the bottom PTMV.  You can see the festoon lamps on the rear of the meter unit. Apparently there are tweak point in the unit. I've never opened it up.
I am restoring a Neumann mixing desk that uses a similar meter and one of the two PTMV units is defective.
I haven't been able to find schematics for it, does anybody have a copy ?
I sent my documentation to the  guy restoring mine. When he’s done with it I can scan it.
Thank you. I have looked everywhere and couldn't find schematics for this module.
If you could also share the calibration procedure that would be great.
Sure, I'll scan what I have when I get it back. I'd like to see more working light beam meters.
I just got an email saying he located a NOS Nuvistor to replace the missing one. The sticky thing is at some point the thermistor was replaced with a cap. Apparently the thermistor looks like a tantalum cap. He has to figure out a suitable thermistor to instal.
He's also just finished a Waveforms 520-A VTVM. I'm excited to get that back. It's very compact and has a large meter with a mirrored scale. I like it better than an HP400.
We had this type of meters on the EMI TG12345 ( 16  )  and on the  EMI-NEVE ( 24  ) at  the EMI studios, in Paris.
When a bulb was blowing during a recording session, you had to wear sun glasses before opening the back panel of the Vumeters enclosure, because the light of all the bulbs was so intense  !    :mad:
Under the instructions of the recording eng. the new bulb had to be slowly rotated until the filament was not making a " shadow "  over the vumeter scale....
Add two fans to blow the hot air out...
What a crazy design it was  ! ::)
HI Paul,
any chance I can get the documentation regarding the PTMV amps ?
I am coming to a good stage with my mixer refurbishment and would love to get the meters properly calibrated.
I sent the documentation with the unit and I don't have it back yet. I know the work is complete. I'm not sure when I'm going to get it back because I have him working on a pair of UE100's for me. They are about 200 miles away so I'm going to wait until the UE100's are done to pick up the PTMV.
Light Beam Meters are so cool!
10 Years ago I still worked in rooms at the government radio station equipped with similar NTP meters.
I got myself one, but failed very hard in replacing the murky mirror.
After spending a long time finding someone recoating the tiny mirrors I completely failed in reglueing the replacement.
This was one of my most unsuccessful repairs ever.
;D
I still have everything ready to install one like this in front of my desk.
If anyone knows a source, please let me know.
I have all the documentation back. I will scan everything. I don't have the ability to stitch together the schematic scans. Does someone want to stitch together the schematics and then post the files in the Technical Documents section?
