rbarreiros
Member
- Joined
- Jul 31, 2012
- Messages
- 14
Hello,
I have a Saffire Pro 26, pretty much the same unit as the 40, just less inputs/outputs/clock/adat etc, with the following symptom, on the 2nd channel, when I gain up the signal, it amplifies up till a value, then it remains at that value regardless of the volume I increase, (similar to a limiter).
I already measured (signal generator + oscilloscope) and tested the whole preamp chain from the interface input, through the analog switches, input opamps, straight into the adc/dac CS4272, and up till there, everything seems to be working perfectly, with the gain working as intended, I am guessing the problem is either with the codec, or post, my gut tells me codec, has this happened to anyone else ? Does anyone know a way of further debugging without picking the soldering iron to be sure it's the CS4272 ? (the de/soldering will be a pain as it has plenty of 0402 caps/resistors very close to it)
Thanks.
Thanks.
