Timjag said:
You will notice a difference between different op amps, if you don't you shouldn't be an Sound Engineer.
Tim
And to add, knowing when an older and slower op amp might be better suited ....
Favoring a 9 v/us slew 5532 with its 10mhz ugb over the 3000v/us slew 6172 with it's ugb that is 10x the 5532 shows that newer and faster doesn't always mean better. I have a pretty nice stash of faster chips now after realizing that a much more simple recap with some added "paralell" bypass caps made the improvements I was looking for and the newer op amps just didn't sound as good to me or even right sometimes.
I've actually found that I don't like the TL072 as much as the pretty much equivalent LF353 in some circuits..... not too sure why but, it just sounds better to me...
I also favor the NJM4562 over the LM4562 in some places as well..... Unfortunately harder to find those for some reason...
And the 5532 can't be faulted in many places.....
At the end of the day for me, the differences heard from pushing certain pieces to their optimal operating points has always yielded more satisfaction compared to replacing op amps . Don't get me wrong, I like having my stuff working at it's best potential and sometimes a recap may not be all that can do this but, I also know I can put that un modded piece in front of someone who is more skilled at the art of using it to it's maximum potential and they will most certainly reveal what I may have been looking for without having to touch a soldering iron.....
If modding and soldering is something comfortable to you, then it's no big deal to try for yourself. If it's not something you're used to, and there are no sockets there to experiment with, there's a possibility you will notice the new jumper wires that weren't there before more than you will notice any major improvements that could've been had with the same op amp or similar......
But we've all been there and this is DIY so, I guess it kinda has to be done. :-[....Just be careful.
dysenterygary said:
Can I start swapping out opamps without having to add additional .1uf caps?
It depends on the op amps you intend to use.
