mg73 Well-known member Joined Dec 9, 2005 Messages 163 Location sweden Mar 4, 2018 #1 I'm looking for the wiring info for the cable between MM1200 and LYNX II module.
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,856 Location Aarhus, Denmark Mar 5, 2018 #2 ..maybe John Klett has it? http://repforums.prosoundweb.com/index.php?topic=8223.0 edit: Found this attached .pdf in our arcives - is for microlynx, not sure if it will work for a Lynx-II though.. Jakob E. Attachments 70d065 - Ampex MM1200.pdf 14.7 KB · Views: 8
klett Active member Joined Nov 9, 2004 Messages 26 Location Carmel, NY Oct 19, 2018 #3 not very well organized but. . . http://technicalaudio.com/pdf/TimeLine/ should be in there and a lot of L1 and L2 cables are interchangeable you are looking for Ampex_MM1200_cable_assy_70D017-20_revC.pdf microlyx is a whole other thing
