Che_Guitarra
Where to buy shallow 19" enclosures?
« on: March 09, 2018, 08:43:49 PM »
I'm wanting to buy a pair of 19" rack enclosures, 1U high, and approximately 130 -150mm or 5 - 6" in depth.  Any deeper will cause clearance problems in this application.  Blank, no vents or other cutouts, sturdy, steel or aluminium.
There's very few options (none, to be exact) to be found locally here in Perth Australia.  This being the case, my usual go-to is Ebay, but i'm not finding exactly what i'm after there either.  I've Googled, of course - many results, but none seem to quite fit the bill.
I'm hoping the knowledgeable heads of GroupDIY can throw me a bone.  Where can you suggest I try?
mjrippe
Re: Where to buy shallow 19" enclosures?
« Reply #1 on: March 09, 2018, 11:02:08 PM »
I always use Par-Metal rack cases but they start at 8".  They do offer a create-a-size series that might work: http://par-metal.com/create-a-size.php
squarewave
« Reply #2 on: March 10, 2018, 02:22:25 AM »
The Redco 6" 1U rack enclosure is nice:
If someone needs them, I have svg, dxf and sketchup files for a blank panel with the 8 holes in front and 4 oblong mounting holes for these Redco enclosures and the holes line up perfectly.
Here is one of my builds that uses the 6" enclosure:
Unfortunately they are in Connecticut USA so shipping will be tough.
« Reply #3 on: March 10, 2018, 04:06:04 AM »
modushop in Italy do a couple of 1U units that are 170mm (6.7 inches) deep:
https://www.modushop.biz/site/index.php?route=product/category&path=20_27_61
Michael Tibes
« Reply #4 on: March 10, 2018, 09:25:08 AM »
https://www.schaeffer-ag.de/en/ has side panels for 1 and 2 U which they cut to order. They are actually affordable if I remember right. I haven't used them yet, but they look good to me.
Michael
Khron
« Reply #5 on: March 10, 2018, 10:10:53 AM »
A while ago, when i was looking for rack cases, i came across this Turkish company, they seem to have pretty good prices too:
http://www.altinkaya.eu/17-19-rack-enclosures?orderby=price&orderway=asc
They seem to do a 146mm-deep 1RU: http://www.altinkaya.eu/19-rack-enclosures/185-rm-110-14.html
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
buildafriend
« Reply #6 on: March 10, 2018, 01:00:18 PM »
I hate leaving negative reviews - their metalwork is great but their service has not always left me smiling
Potato Cakes
« Reply #7 on: March 10, 2018, 01:22:36 PM »
Do you have just the drill hole dimensions for this enclosure?
Paul
mjrippe
« Reply #8 on: March 10, 2018, 02:01:45 PM »
Really?  I've bought dozens and never had a problem.
squarewave
« Reply #9 on: March 10, 2018, 10:18:08 PM »
You mean the 8 holes that need to be in the front panel? Yes, they're 5.1" apart horizontally and 1.376" vertically and then that 4x2 grid of holes are centered horizontally and vertically. The tabs that the panel screws into that protrude down / up from the edges are 0.313x0.212 with 4-40 tapped holes. Clearance inside is 1.55".
Redco 1U rack enclosure panel tab dimensions:
Note that this drawing is a blank panel (silver) with the mounting tabs and a small bit of the top and bottom edges (black).
I think this information alone should be enough to check clearance for a panel but I use Sketchup to check clearance around the tabs because I place components within a few millimeters in some cases. Mocking up with Sketchup is critical. That's always my first step first to visualize the concept and then to check clearances.
iampoor1
« Reply #10 on: March 13, 2018, 12:42:20 AM »
Same. My only minor complaint is that they dont tell you the shipping price until they charge it.
squarewave
« Reply #11 on: March 09, 2020, 12:03:47 AM »
I just noticed Redco now as a 2U enclosure available in 3", 6", 8" and 10" depths:
  https://www.redco.com/Redco-CH2-2U-Rackmount-Chassis-Box.html
Same style as the 1U so the front and rear panels do not have special flanges or anything that would exclude using a panel from FPE, cam-expert.com, etc.
« Reply #12 on: March 09, 2020, 12:40:43 AM »
BUD makes a 4" deep chassis.
Gold
« Reply #13 on: March 09, 2020, 01:21:54 PM »
I’ve bought a lot of enclosures from them. I tried to get ahold of them last month. Called every day for two weeks and sporadically for the rest of the month. No answer.  I also sent a bunch of emails. No response.
Ricardus
« Reply #14 on: March 09, 2020, 07:46:07 PM »
Collective Cases has a 5.5 inch deep back box for their racks.
Audio mastering for hire..
mjrippe
« Reply #15 on: March 09, 2020, 11:08:34 PM »
I don't know what to tell you, Paul.  I have ordered twice from them in the last month with no problems.  I fill out the form online, get a paypal invoice, pay it, and have my cases the next day.
Gold
« Reply #16 on: March 09, 2020, 11:30:11 PM »
I need to order pieces as well as full cases.  You can’t order pieces online. I’m not asking for anything custom. Just things like rear or side panels in the standard dimensions.  I’ve ordered tons of pieces  in the past. If they no longer want to sell them they could at least tell me.
