Old Component Replacement & Modern Equivalents
sr1200
Long Island, NY USA
Im looking at an old UREI 530 eq.  The schematic (link below) has a few components that Im not sure what to use.
First is a set of diodes listed as CR# VI0 can't seem to find anything besides it might have been a crystal rectifier, but just looks like glass diodes. ( theyre near IC1D and near the output transformer)
second is 5117 (Q3) looks to be a transistor (top middle of schematic before the output transformer)
third and fourth (same area) is a pair of transistors listed as MPS U55 and MPS U05 (Q1/Q2) they both physically look like a similar package to a voltage regulator (TO)
If anyone has some insight would be greatly appreciated.  :)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiwhtCOkOXZAhUOvVkKHfjEAmIQFggpMAA&url=http%3A%2F%2Fwww.jblproservice.com%2Fpdf%2FVintage%2520JBL-UREI%2520Electronics%2FUREI-530.pdf&usg=AOvVaw0OcPetr_I9Yehmuczy1gHu
CR2 and CR3  are the same as CR4, which is 1N4740A (10V 1W Zener Diode)
MPSU05/55 is an obsolete 2A 60V 10W PNP transistor made by Motorola.
A possible modern replacement (still in production) is MJE253.
