john12ax7
Recording to am external USB hard drive
« on: March 20, 2018, 11:25:33 PM »
Looking for a way to work on sessions at two different studios. Was wondering if it's practical to record directly on an external drive,  was thinking of using USB 3 with either an SSD or regular 7200 in an enclosure.
I'm using Pro Tools on Windows 7 PC. Have used a dedicated internal drive until now.
ruairioflaherty
Re: Recording to am external USB hard drive
« Reply #1 on: March 21, 2018, 12:24:19 AM »
I've certainly done lots of large sessions on older USB 2 drives, both recording and mixing.  That was on a Mac of course, PC could be different.
john12ax7
« Reply #2 on: March 21, 2018, 12:36:52 AM »
I knew people used firewire and thunderbolt regularly. My concern was all the other things hanging on the USB bus the computer needs to deal with possibly causing conflicts.
But it's good to know if can work.
leitmo
« Reply #3 on: March 21, 2018, 01:39:36 AM »
I record and mix on external ssd drive connected to a hub with other drives, mouse and daw controller without issue.
ruairioflaherty
« Reply #4 on: March 21, 2018, 01:45:27 AM »
It may well be the case on PC, I just don't have the recording experience to know.
 I've said here before it takes more effort to keep my one Win 7 PC on the bench running than it does my households other 8 Apple devices put together…  but that might say more about me than the platform,
iampoor1
« Reply #5 on: March 21, 2018, 02:24:17 AM »
Might just be a familiarity issue. I am very familiar with Windows and minus crashing 2 times due to random memory leaks, and crashing due to un plugging a usb audio interface, my windows 7 install never crashes. It's well tuned and I am familiar with it. I  have had the same install for 4 years now. But if you put me in front of a mac.....well I can barely use the thing.  ;D
tony hunt
« Reply #6 on: March 21, 2018, 03:06:25 AM »
I record to an external SSD through USB3 for a good few years now. Samples and DAW resources are also on external SSDs. It seems to keep the load on the main drive down.
The OP is right that the USB bus can be an issue. A good quality and reliable powered hub becomes really important.
The RME UFX interface series lets us record directly to a USB device straight off the interface. Other interfaces may offer that too.
A good backup system, especially when on the move is just as important. This may lead you to backing up to Dropbox, which could be doubly useful if you are on more than one location. With Drobox linked to your other location, there would be no need to take physical drives.
