ethan-
whats your application? They sound different, it all depends on what you are after. I cant much tell the difference between solid state and tube at the bottom of the power demand of whatever device you are using, but at the top its night and day. In a guitar amp, for instance, a 5y3 for instance will make the amp go as loud as its gonna go up to say 7. After that its all compression and sag from the rectifier. This doesnt happen with a solid state rectifier, or at least it doesnt translate to my ear as that, as you go past 7 on the volume with a solid state rectifier, the volume increase is way more linear and you get more distortion and no where near the same quality of compression. And its big compression Im talking about here. In a tube mic power supply its the same thing. If you take a singer and have him totally lay into a mic with a tube rectifier, I notice the mic absorbs much more level before clipping completely and have always written this off to the sage from the rectifier. Im sure there is audiophile stuff and other reasons for comparison, but from a practical standpoint, this is the one issue where I find the two to have the most useful difference. Sometimes you want a more linear top, sometimes you dont.
dave
