Schematics for S800
Potato Cakes
Nashville, TN
Does anyone have schematics for the S800? I have two, the one I can read doesn't have the values listed and the one that has values isn't legible when I zoom in.
Paul
Excellent, Peter.
Doing a Tac Scorpion mod later this year and a forum member pointed out the console EQ and S800' layout were very similar. Going to see if I can marry the two.
Paul
Attached is the one I had,  but it might be the blurry one you are referring to.  Maybe peterc has a better one.
I ended up separating things out and then wiring it up in a simulator to verify things and get the response I wanted.  Things change somewhat when using a separate opamp for each stage.
The good news was the simulation and built unit were spot on in agreement.
That is the one that I have. I can make out most of the labels. I'm going to attempt to redraw the S800 with the existing S1000 channels strip schematic post my attempts on the Scorpion thread I have going.
Paul
