In the original M49, there was a rubber plate in the bottom that the transformer and the electronics was mounted on.
The reason for this was to mechanically isolate the electronics and the capsule from the microphone body.
I have made a design in Autodesk Fusion 360 for a “rubber” mount that can be used for Banzais M49 bodies and Dan’s circuit boards.
I have used a 3D printer and printed the mounting plate in both a hard plastic version and in a soft, rubber like plastic. The soft rubber plastic does reduce the mechanical noise quite a bit.
If anyone is interested I can share the Fusion 360 design. You can then print it or modify the design as you like. Just drop me a PM.
The pros is that the isolation will be better. The cons is that it will raise the capsule mounting plate a bit. I had to shave of two millimetres on the top PCB that holds the capsule anyway.
