this transformer was barking like a dog at max level, causing spurious response that was blowing fuses and taking out tubes,
the first 1000 turns were completely dry of varnish, so they did not vacuum impregnate or leave it in the tank long enough.
we will rewind and dip it good this time, and maybe try a full 1" stack of EI 100 in 29M6 steel and see if we can not get a little more punch at the low end,
it will be interesting to see what happens to the 100 K Hz freq response and sq wave tests.
the extra varnish should bring the response down to around 60 K. so this is a good troubleshooting tool, if the response is too good, there might be a wax or varnish problem.
MaCintosh asked Doc Hoyer to build them some outputs for some power amps with no varnish,
he told them they were crazy, that the wires would break,
they wanted them anyway for the extra flat response so he shipped them and the wires broke.
