FS: "Poor man's" Pultec EQ, two-channel
« on: April 15, 2018, 03:46:59 AM »
/* Now up on eBay */
Hi all,
Up for sale is my Ian Thompson-Bell designed "Poor man's" Pultec EQ. A clean build!
Two channels in a Par-Metal 2RU case. Gain makeup is via Ian's 'Classic Solo Lo Hum' design with 6922s. Transformers are Sowter 3575 on input, Carhnill VTB2291 on output. Grayhill selectors, Switchcraft in/out toggles, Bourns pots, Carhnill VTB9042 inductors, Wima caps in filter section. All top notch parts.
I built it trying to fit two channels in one chassis. This I did; I drilled for an on-off switch on the front panel not realizing the mains wiring to the switch came too close to the LF section on the front. Thus, this induced hum on that channel with the EQ switched in.
The workaround is to forego the switch wired to the front panel: either hardwire the power transformer to the AC inlet (fused, of course =) and switch unit on/off via a power strip or put the switch on the rear panel.
The project was shelved when I obtained a pair of Lang PEQ-2As late last year.
References available.
Chris
« Last Edit: May 19, 2018, 07:01:39 PM by fazeka »
"Kind of like going into Safeway at 4 in the morning and chugging a beer in the produce section; been there, done that." - CJ
"We're not making an atomic bomb, just cooking a few electrons." - PRR
Re: FS: "Poor man's" Pultec EQ, two-channel (lower price)
« Reply #1 on: April 22, 2018, 08:20:37 PM »
Bump for lower price
Zebra_PD
« Reply #2 on: May 24, 2018, 02:31:32 AM »
Hi, what's your asking for it? Where are you located? :)
"The looks is half the sound"
My company:
www.zebrastudios.se
mylesgm
« Reply #3 on: May 27, 2018, 06:48:06 PM »
Do you have an eBay link? M
Check my work at www.mylesmumford.com
Last post July 07, 2008, 11:56:08 AM
by bodega
Last post October 08, 2014, 10:25:07 PM
by skal1
Last post August 09, 2013, 09:29:39 PM
by mikeyB
Last post January 24, 2015, 07:34:34 PM
by ruffrecords
