mu metal is commonly used magnetic shielding.mkiijam said:Simple test setup. Swapping transformers around. All else same. One transformer seems more sensitive to picking up 180hz hum from power supply transformer.
Is this a common, known thing?
Even if construction was absolutely identical, Mu-metal can loose some of its properties with heat, stress and shock.mkiijam said:Simple test setup. Swapping transformers around. All else same. One transformer seems more sensitive to picking up 180hz hum from power supply transformer.
