D d.d.sound New member Joined Nov 25, 2013 Messages 3 May 2, 2018 #1 Hi! My frist post. just finished assembling this unit. All voltages seem correct. The problem is that when I raise the input gain a strong feedback came in. Should I use shielded cables as show in the schemati ? Thanks in advance?
scott2000 Well-known member Joined Feb 21, 2015 Messages 3,917 Location Sunny...Sometimes Florida- USA May 2, 2018 #2 d.d.sound said: Should I use shielded cables as show in the schemati ? Thanks in advance? Click to expand... I would guess if it's in the schematic then yes??? You can post your question here too maybe as this may get lost in the mix..... https://groupdiy.com/index.php?topic=646.3820 And maybe scan through the thread if you haven't already??? https://groupdiy.com/index.php?topic=646.0 I'm sure someone can chime in to help you out...... Good Luck!!!
