absrec
You mentioned turning both trimmers fully CW. What happens when you turn GRSCALE the other way? Does it lower the voltage (more negative) at U10 or does it get closer to zero (which we want)?
Measuring U10 PIN 1 to GND the voltage goes from +365mVDC (Fully CW) to +438mVDC (Fully CCW). GRSCALE is the recommended 100k Trimpot.
Additionally, measuring U8/U9 PIN 4,6,8,10 to GND - I'm getting a reading of negative (-)1.38VDC and turning GRSCALE doesn't have any affect on the reading.
What did your QBIAS end up at (measured at the right side of R48)?
From R48 to GND I got negative 3.347VDC.
Just to make sure we're talking about the same point, I included a screen shot. The other side was pretty close. Maybe 200mV difference. Not 100% sure I understand what the QBias even does. I did adjust it along with the distortion trim according to the build guide. Both of those adjustments worked exactly as you said they would.
fripholm
That’s strange. Turning GRSCALE should definitely result in a change, also at the QBIAS voltage you are getting.
Yes, you were measuring the right spot.
Are your FETs matched? The QBIAS setting puts the compression FET into slight conduction and is different for each FET. For the GR meter circuit to show the correct amount of compression, the second FET needs to be matched to the first one. When idle, the QBIAS voltage gets added through the second FET & the GRSCALE trimmer to an offset provided by GRNULL.
Can you post a high resolution photo of the complete right hand side of the stuffed board (the one with the comparators and U10)? Maybe I can spot something that’s not quite right...
absrec
Is this clear enough? I feel so vulnerable. It's like sending someone a close up of your own face. :)
absrec
If I did it correctly. I followed your FET matching scheme and picked the closest two. They seemed to vary more in voltage than current from device to device. I only had 10 to get a match but I actually found 3 pairs that seemed within the 10% tolerance stated in the build guide. I'd say more like 1-2%. Basically the readings were about identical on the ones I ultimately considered pairs. I think the Vp was around 3.86-3.87V and Idss was .46-.48mA on the pair that made it to the board. I'm just going by memory so if those readings seem atypical, I may have to go do the test again and report back.
fripholm
Thanks, the picture is clear enough. I’m not in the studio at the moment - will check it in the morning.
absrec
UPDATE - It was apparently a problem with the LM339ANs. They are the TI brand. I ordered more LM339s a few days back and they showed up a few hours ago. I swapped them out and now it works. This just confirms what others said in earlier posts. I have the NSC (?) version I believe that's who makes it. They say SM8824 as well as LM339AN on the ICs.
Thanks Thomas! Great sounding project. Thanks for your time & guidance.
fripholm
Awesome! :D
This is the exact opposite of what I recommend in the guide after TillM ran into something similar with the type of comparators he was using. To double check I've just replaced the ST LM339N in my mono unit with TI LM339AN (presumably the ones that gave you trouble) and they work just fine. I haven't found a hint for any differences in any of their datasheets either...
In other words, there's no general recommendation what to use and what to avoid when it comes to quad comparators. When in doubt, just try a different brand.
Anyway, I'm glad you've got it sorted! :)
scott2000
Would be neat to know what is going on with these comparator gremlins.... There must be some reason I'd imagine. Maybe just some goofy chips or , in this case, the desoldering maybe....
Is there something before being calibrated that could cause damage?
Of course it's moot now.....
absrec
Awesome! :D
The ones I’m using are marked LM339AN. They are just a different brand.
absrec
Could be exposure to excess heat. Maybe they are just sensitive devices. Not moot if anyone else decides to build one of these units. I would just be sure to use IC sockets so if there is a problem, you don’t have to risk damage to the chip and PCB. Lesson learned.
kante1603
I agree with Scott2000,something is strange here.
Damaged by excess heat while desoldering,o.k.......but something must have happened before.
Now I seriously wonder:
a)are those chips sensitive for ESD
b) what happens if they were mounted the wrong way around?
Best regards,
Udo.
absrec
Best regards,
Udo.
I kept checking the component layout over & over for errors like incorrect values, incorrect polarity, etc. but never managed to find anything. Once I changed the comparator ICs, the circuit began to function as described.
I never applied power to the board when the chips were installed upside-down. I found the error and corrected it prior to the initial smoke test.
Curious if anyone has found a mouser part or digikey(or-if anyone knows where else I can get them in canada!) part # for 2x13 header and socket? I haven't had any luck searching, but its entirely possible I'm just using their search function wrong.
absrec
Not from Mouser but… This is what I bought.  It’s ab assortment of different headers, all with a 2.5 mm spacing. Just snap or cut down to size depending on what you need
Glarks 112Pcs 2.54mm Male and... https://www.amazon.com/dp/B07CWSXY7P?ref=ppx_pop_mob_ap_share
this is perfect, thank you!
Last post March 17, 2005, 06:04:37 PM
by Svart
Last post March 07, 2013, 08:50:19 PM
by Bhudie
Last post June 20, 2011, 09:35:44 PM
by mikefatom
Last post July 12, 2019, 08:02:25 AM
by dribro
