Re: Vintage Windings EQ-1A inductor in EQP-1A builds - the ring is gone!
« Reply #20 on: September 23, 2018, 06:34:32 PM »
Question is not for me, but I can answer from my experience (knowledge). Soft Magnetic materials are not linear by frequency by many aspects, so in this case by permeability. So, Al value is different for different frequencies. Especially with molypermalloy cores. People who produce this "innacurate" inductors probably measured their values on 1khz what's not enaugh for this kind of filter.  Producing accurate multitap inductor for Pultec's has to be calculated and measured carefully.
OK, I get that but molypermalloy is little more than regular 80%nickel used in transformers and has a very large frequency dependency. On the other hand the Carnhill type of inductors most often used in EQ designs are made of ferrite which  does not.
ian
Moby
« Reply #21 on: September 23, 2018, 06:38:51 PM »
ian
They use Moly-Permalloy toroids for their EQP inductors. Also, not all MP cores are "right one" for this design.
For microphone transformers,  BV.8,  Bv.11,  Bv.12, etc.. contact me at mobyelectronics at gmail dot com
« Reply #22 on: September 24, 2018, 04:07:55 AM »
Sorry, you lost me. Who does?
Moby
« Reply #23 on: September 24, 2018, 04:09:08 AM »
Carnhill  :)
« Reply #24 on: September 24, 2018, 05:28:04 PM »
Carnhill  :)
Which inductor part numbers would those be?
Moby
« Reply #26 on: September 25, 2018, 02:59:12 AM »
http://www.audiomaintenance.com/acatalog/CA-18-VTA1444_extended_info.html
Ah, now I understand. I was thinking of the VRB9042 through to VTB9055 series of ferrite EQ inductors. The permalloy ones are a fairly recent introduction to the audiomaintenance catalogue. Presumably these are used in the search for some kind of authenticity in clones.
Moby
« Reply #27 on: September 25, 2018, 03:33:49 AM »
MP sounds quite diferent but
AL is more frequency dependant.
« Reply #28 on: September 25, 2018, 05:51:52 PM »
Ferrites did not become commercially available until about 1945. The EQP1A was designed in the early 1950s so ferrites were certainly available to them. However, the EQP1A design was based on a 1930s Western Electric EQ design intended for telephone circuits where distortion was not a primary issue. Clearly the Western Electric design did not use ferrites. Perhaps the simply copied it, telephone distortion and all.
Moby
« Reply #29 on: September 25, 2018, 06:02:20 PM »
A standard MPP core saturates at around 7500 Gauss. A ferrite core saturates at around 4500 Gauss.
« Reply #30 on: September 26, 2018, 03:18:49 AM »
But I doubt if either of them ever saturates in an EQ. I think it is the shape of the BH curve that is more important plus the point you made about parameter variation with frequency. I cannot think why anyone would choose to use a permalloy core in an EQ design today.
vari-mu
« Reply #31 on: October 08, 2018, 04:51:43 AM »
    Hi !
  I have a certain amount of Russian moliphermalloy from semirings MP-140 (Al=140) and MP-250 (AL=250)
  and I made inductors for my EQ Pultecs (7 pieces) 5 years ago.
  Recently I got one inductor, wound on two half-rings MP-250 (AL = 250x2 = 500) for measurement. My LC meter allows me to measure L on two frequencies:  UP (hi freq.) and DOWN (low freq.), which he assigns independently.
The results can be seen in the picture:
 L = 39.268 mH at 15440 Hz and 41.39 at 2460 Hz, Al= increases by 5.4%
        next tap of inductor
 L = 80.54 mH at 10 790 Hz and 91.21 mH at 1670 Hz, Al= increases by 13.2%
   Depending on the number of turns Al= "walks" between 350-250 at high frequencies and between 450-320 at low frequencies.
 I can not say anything, just information for thought.
Maybe my device does not work correctly.
 Vladimir P.
Moby
« Reply #32 on: October 08, 2018, 05:02:44 AM »
    Hi !
 Vladimir P.
Hey Vladimir. "Hi and low" doesn't tell much, but nonlinearity of the core depends from model to model, batch to batch. To trim Pultec inductor correctly variable frequency L meter is must. It has to measured at working frequency, for example 16k. I use HP meter with sweepable singnal generator with accuracy of 0.5% at corner frequencies  ;) and again, it has to be double checked in LC circuit.
Has there been any progress with this?  I'm not satisfied with my cinemag inductor and would like something more authentic.  I have no idea if I have ringing or not and if I need to tune the Zoebel network to work with the Sowter 1475.  The high boosts just seem a bit harsh to me.  Did I miss a new thread that was started?
Moby
If you ask about inductors, feel free to contact me by mail (see my signature) I have it on stock  :)
Last post October 25, 2006, 11:13:06 PM
by drpat
Last post September 04, 2008, 11:29:28 PM
by drpat
Last post August 29, 2018, 05:19:33 PM
by AusTex64
Last post August 24, 2019, 08:26:49 PM
by ruairioflaherty
