So I had heard from multiple sources that the Bento Box's (cheap 500 series rack) main issues were from the Cheap power supply inside the unit. So I decided instead of building a complete new unit I would replace the power supply in mine with an external supply via a JLM powerstation. So I am using a 5 pin XLR to transfer power from the PS to the box.
My question is that I would like to add a switch on the front of the rack so I can switch it off and not have to turn it off at the power supply. Can i put a swith on the +16 and -16 rails from the PS and when they are turned off not hurt anything having the 48V rail active?
Is it going to hurt the PS to have it on all the time?
If all else fails I will just turn it off via the Power supply but I was hoping to be able to implement the switch on the rack.
Thank you for your help,
Dustin C.
Dustin C.
