Hello Diy Family,
I'm looking for a good/reliable circuit to balance and unbalance signal in mixing console "insert" section.
I'm using Trident MTA console which I would like to upgrade with "balanced" patchbay.
Every channel has "Insert" socket where tip is send, ring is return. What I would like to do is
Make a small pcb near each channel. From each channel I would like to balance signal (on that pcb) , send it to the patchbay, then from the patchbay balanced signal goes back to the pcb where I would unbalance it and send back to the channel.
I found some circuit to balance &unbalance signal, but maybe you did this and can give me any advice which works better / reliable.
Thank you guys!
Thank you guys!
