FarisElek said:I have some questions about this build. Gregory was being really good at getting back to me about getting back to me but never did...
Drip sells kits? Isn't the idea of buying a kit that you get support too.
JMan said:Drip explicitly does NOT sell kits, they sell PCBs with accompanying build documents. Gregory is notoriously inconsistent with communication, so sometimes you may get an answer from him, but much of the time you will get no reply. I’ve personally emailed him on a few different occasions, and have literally never received one single reply even acknowledging my messages.
The projects themselves are awesome, but God (and GroupDIY) help you if you run into an issue that you can’t figure out yourself. :
scott2000 said:I guess another helpful thing would be to follow the original Sta level schematic and basically trace through the boards to get a feel for what is going on.
FarisElek said:I have some questions about this build. Gregory was being really good at getting back to me about getting back to me but never did so I'm going to attempt to find out some of these questions here as he seems really busy.
1) The XLR PCB has holes for underneath the relays for Diodes. I believe they all say "D9". Are these alternatives to the Relays? I ask because there is no mention of them in the build information and they weren't any extra diodes in the BOM. They're also not labeled as to which diodes they were referring to. Since I'm pretty sure these are universal XLR PCB's, i'm thinking it's for a different build and that I just use relays in this one. I may be very wrong as I'm pretty sure I've used relays along with diodes in other builds.
2) There is no information for set up once everything is wired. How do I calibrate all the voltages and trimmers correctly? Will that not work because I need the load? Which trimmers do what? Some of them are obvious but others I'm not exactly sure.
3) On some builds as well as the collective case panels there is an area for the meter zero adjust. There is no information of this on the build, how do I instal it? what kind of pot should I use?
4) Is there any affordable meters for this build that are shaped like the Simpson model 47 but not $200 a pop? I have some old vintage meters lying around I can use but I just noticed today that the lamp is potted in some clay and the bulbs are dead so I can't use the whole lamp mechanism without jerry-rigging some LED into it, on top of that the GR isn't right and I'd rather just get a new one.
5) The lamp/6.3v seems shorted to ground even on the SMA connector despite if I cut pin 15. What's that about? The main PCB itself seems to have shorted to ground somewhere. It seems like it's because the IDC header pins for ground and 6.3v are connected. But even if I cut pin 15 on the control board there is continuity. Is it because the electricity flows one way and I don't have to worry about continuity? Also, my high voltage 600v transformer wires have continuity with ground on the PSU pcb too. Is this another thing that's okay because the diodes move the current away despite being connected to ground?
I'm awaiting the output iron but besides that I'm completely that and what I mentioned above, I'm completely done. I'm really nervous about it because I've never built anything quite like this + the lack of build info.
Thank you,
Ryan
FarisElek said:Thanks for the heads up! It totally says the 10k trimmer is the zero adjust. That's interesting because in the build pics he uses a variable resistor style trimmer, but in the Collective Case case there is a position for a potentiometer for adjusting the zero adjust. Does that mean it's same to assume I can use a 10k audio pot in place of the variable resistor and put that on the front panel in it's place?
The next pot I have no idea what it does is that there is a second 100r "balance" next to the 10k meter pot. I know it's not the 6v6 balance because there is another pot actually labeled "6v6 balance".
Any ideas?
Ryan
FarisElek said:Thanks Bowie. I’ll definitely follow the pot next time I open it up. Although I do believe it is 6386 balance as I’ve read it was included in later models.
A couple things I’d like to know if anyone has the answers:
1) What fuse should I use with this build? The original Gates had a .2amp slow blow but since it has double the tubes should it be a .4amp? It had a solid state psu though? How do I calculate what I need?
2) What are the steps for balancing the 6v6 and the 6386 cathode (assuming that’s what the other 100r pot is for) with the trimmer resistors? IE where are the test points? What voltage does it need to be etc?
3) should I test voltages without tubes in? I’m really nervous about the upcoming day when it’s ready to turn on and I have no idea what the calibration method is, what safety measures I should take, etc. I followed the silk and the eratta to the T. Even (at least temporarily) opting for the SS Psu. So I shouldn’t have any problems, but I don’t know?? I’m just assuming the heater voltage and the B+ will be within reason and I only need to make minor adjustments with the pots?
Ryan
mikeij said:I just started this build. I've got the new PSU PCB as well which caught me by surprise. The majority of the changes seem to be silk screen and layout, but a couple components were added - fuse holders on the 2 legs of the 600VAC rail and an "unregulated dropping resistor."
Was there anything useful in the old build docs? If so, would you mind forwarding it? Looking forward, I'm probably going to have a lot of the same questions you're asking, so if you can share any of your learnings, it would be appreciated.
Were you able to find a good source for knobs?
FarisElek said:i followed the eratta for now + choke. i installed tube socket as i THINK all you have to do is cut the diodes and use the tube but i’m not going to take any risks yet. knobs i used rca style knobs from tube depot as you can get all your sockets there too. my output transformers will be here by monday and i’ll probably wire it up and get the thing running by then. if all goes well i’ll try to write out all my revelations and i’ll 100% be available for questions. good luck,
