Dimis76
Rode VideoMicro and XLR connection with Phantom Power
« on: May 29, 2018, 10:45:12 AM »
Hello everybody, i am new to this (i also hope i am at the correct section of the forum)!!
I am a videographer and till now i have used several microphones that were intended for video cameras with XLR connection which also required phantom power.
Recently i have purchased a RODE Videomicro which has a TRS connection (i think) but needs a "bias or plug  in power of 2-5 volts - I read somewhere it can go up to 10v - Here is the webpage of the specific Mic http://www.rode.com/microphones/videomicro
So the question is how can i make a diy cable from 3,5mm TRS plug to Reduced power 5V (from 48V) XLR?
Regards
rogs
Re: Rode VideoMicro and XLR connection with Phantom Power
« Reply #1 on: May 29, 2018, 08:29:52 PM »
You might find this is the simplest way to solve your problem - the Rode VXLR+ :  http://en.rode.com/accessories/vxlrplus
Not to be confused with the Rode VXLR :   http://www.rode.com/accessories/vxlr     No facility for phantom power with that one..
www.amx.jp137.com - A DIY RF condenser mic project
rogs
« Reply #2 on: June 04, 2018, 06:17:11 AM »
Did you go for the Rode device , or did you find an alternative solution?...
« Last Edit: July 27, 2019, 05:09:30 PM by rogs »
Dimis76
« Reply #3 on: July 26, 2019, 03:01:03 AM »
No i am still looking....
I was thinking a voltage divider or an LMxxx solution...
Has anybody tried that?
« Reply #4 on: July 26, 2019, 04:13:29 AM »
I'd just go with Rode's adapter since it's made for this purpose specifically. Plus if anything goes wrong you won't void your warranty.
rogs
« Reply #5 on: July 26, 2019, 05:07:45 PM »
As suggested above, the Rode adaptor is probably the easiest solution, but you can build something similar for a bit less cash..
The attached notes suggest one option which seems to work pretty well.... The voltage divider with the values shown gives an off load output of around 7V  - dropping to between 3V and 5V for most electret PIP mics..
There's not really any need for regulation with this kind of adaptor.....
« Last Edit: July 27, 2019, 04:19:01 AM by rogs »
RuudNL
« Reply #6 on: August 07, 2019, 04:32:36 AM »
In the case of a transformer balanced microphone input, the audio is also going through C2.
Personally I would use a larger value for this capacitor.
There is a solution for every problem!
http://www.vansteenisaudio.nl
rogs
« Reply #7 on: August 07, 2019, 07:52:17 AM »
You're right of course Ruud .... about -30dB of attenuation @ 1KHz, but only around -12dB @ 100Hz ...Time to make C2 another 10uF 50V perhaps?....
Now, just need to squeeze that into the XLR!.....
Last post July 01, 2004, 06:27:12 PM
by jrmintz
Last post March 09, 2007, 05:39:46 AM
by clintrubber
Last post December 22, 2008, 07:57:37 AM
by evil grill
Last post May 25, 2012, 11:06:35 AM
by pucho812
