boji
So for reasons that mostly have to do with mission creep and being new at design, surprise! I'm dealing with limited faceplate real estate on my console input card.
As it is, I'm left with a button I previously slated for VU pre/post, but I'd like to get your opinions on possibly trading it out for an input pad.
The reason I'm leaning towards the VU is because Slot 1 on the console (entirely separate from the input card in question) will house mic pre's and they will have standard -20db pads. However, I could see value in having another pad for heavy line level in's, or to gain up a micpre doubly more than normal before being passed to the prefade amp stage.
btw, the plan is to use the line level in's mostly for daw mixdown so unruly input gains/devices won't be a common occurrence. Some of the pre's will also include hi-z inputs. However I simply don't have the experience to know which would serve me better over time : having a VU that can be selected for both pre and postfade gain staging, or an input pad for the occasional wooly inputs.
Any advice / suggestions would be appreciated.
Edit: Forgot to mention this an inline mixer design, so if it wasn't obvious, single channels accept both recording and playback.
