Hi I am building an D-EF47 Microphone .I have the Dual 408A/6028 Board and was wondering if I can replace the 408A with the 6AK5W/5654 tubes. I use the Alctron TPS200.! The heater Voltage is 6V, B+ 120V... Like that the microphone
works (Cardioid mode) but I have kind a ground humming noise ..I tried everything but no luck.. Maybe my voltages or some values in the circuit should be changed .. any suggestions.??
Thanks for the Help-!
