12strings2hands
Member
- Joined
- Dec 13, 2017
- Messages
- 12
I've got an MXL 3000 that is very easy to work on, but I've found it captures too much above 10k. It might even be noise, I'm not sure.
The circuit is almost exactly a V67 except the input stage is direct from capsule to fet. I know this circuit has been a target of modding to an 84 type by removing the transistor follower and replacing it with a higher ration transformer. I've replaced the transformer. My question to you all is can I simply cut the traces at the 2 'x' marks and connect the the 'A''s together?
2nd question is - would a C12 type capsule work better with these changes than say, an 47 or the existing 67?
