Ruffrecord's PCB Emporium Closing Down Sale
Norfolk - UK
Sharp eyed readers will have noticed that Ruffrecord's PCB Emporium has disappeared from the White Market.Most of the PCB designs are quite old now and sales have slowed to a trickle. I have also started to open source many of the designs so people can make their own boards. So apart from a few still popular boards I am selling off all my current stock at knock down prices. Shipping etc. will be at my usual fixed rate depending on where you live. Once these boards are all sold I will open source the Gerber files for them. Here is the initial list of boards and prices:
PMEQP1A MK2 + MID (LORLINPULTEC) was £7 now £2  (11  3 1available)SOLD
3 Band Pultec (original) was £9 now £3  (15 7 5 3 available)
3 Band Helios Type 69 EQ  V2 was £9 now £3  (16 ) SOLD
3U Helios69 + Tube gain make up was £15 now £5  SOLD)
3U 3 Band Pultec  + Tube gain make up was £15 now £5 (8 6  4 available)
Lunch Box External PSU V2 was £15 now £5 (32 30 available)
HT250 was £4 now £1.50  ( 37  35 33  31 available)
Phantom Power Supply was £8 now £2.50  SOLD
PLUS
A few obsolete but fully functional boards:
Eurochannel - the original mic pre and gain make up PCB (2011) for the EZTubeMixer project. This early version has provision only for a Sowter mic transformer and is laid out for the standard  Grayhill 12 way gain switch. It has no push-buttons for mic/line/phase/phantom and pad. Instead of Molex connectors for internal connections this first version just has PCB pads. Probably a collectors item by now. Only 2 available at £5 each.
EZMixer TwinLineAMp V1 - the original TwinLineAmp (2013). No Molex for internal connections  (pads instead). Provision for Sower,Jensen and Cinemag transformers. You can make a very nice pair of 54dB gain mic pres with this board. One only at £5. SOLD
Classic Solo. The original board (2015). Configured for 12V heaters only, otherwise identical to later versions. Two one only at £5 each
Classic Solo V2. The successor to the above board. Configurable for 6V or 12V heaters. Otherwise identical to the original. One only at £5. SOLD
Euro Proto. The very first PCB I designed for the EZTubeMixer project (2011). This board has provision for three B9A tubes, and a bunch of resistors and capacitors plus the 32 way connector that was the centrepiece of the EZTubeMixer design. You could build many different projects using this board. One only at £5.  SOLD
I will try to post some pics and additional data later. If you are interested in any of these please email me - the address is in my profile or you can find it here:
http://www.customtubeconsoles.com/ruff-records-pcb-empporium
Please do not PM me as the box gets full very quickly.
dasnevestheo said:
interested in PMEQP1A MK2 + MID
I have reserved the last one for you. Email me your Paypal email and shipping address and I will invoice you. My email is in my profile.
