hey there,
maybe someone here can give me a hint. i just built a pultec from spare parts i had laying around. its solid state using an api opamp. i did stick to the attached layout.
my frequency response is off. massive high end loss in bypass and eq in mode. the rest of the circuit seems to work as it should.
i did use a 150:600 transformer on the output while the original asks for a 250:600 one. could this cause my issues? or would it only effect my levels? an answer to this would really help me. if i can rule out the transformer, i will have to tripple check the filter section... cheers!
