EMI TG 12414 pair clone and other stuff
masteringpole
France
-EMI TG 12414 pair clone for sale, no trade, only this pair will be available.2000€pair
-BBC LL/88 ALC
4 pcs BBC : 20€ each
LL/88 ASC:
35mm in diameter and 40mm in height with bush mount.
ex-BBC audio input, output or isolation transformer
1:1  600:600  Mu-metal can
WHITE Shield
YELLOW-BLUE PRI  32 Ohms  DC
RED-GREEN SEC  55 Ohms  DC
Primary: Yellow (+) / Blue with the White wire as a centre tap
Secondary: Red (+) / Green
-ANALOG OBCESSION DRIVER 76, 15€/pcs 6 available
-ANALOG OBCESSION 1176 compressor style 30€/pcs 7 available
-TG LIMITER board +diode OA202 matched+ bcy 71and bc109 based on old fester proto board 100€
RELAY FOR SALE
Panasonic NAIS agn 20012 relais, pcb, DPCO, 12 vcc 5€:pcs 30pcs available
NEC EA2-12NU  5€:pcs 150pcs available
TELEDYNE 712D-12 DPDT PCB Mount 10€/pcs 213pcs available
LAWO V970 preamp
SOUNDCRAFT DC2000 POWER SUPPLY APS 500
