Hi Folks,
I built an EQ a few years back based on the following project that had a Pultec type filter and BA283 makeup gain section:
https://groupdiy.com/index.php?topic=43413.0
When I built it originally, I put the filter in one case and the amps in another due to not having anything big enough to hold it. I'm trying to put it all in the same case to make it look better, but I forgot how I had it wired up, specifically where it had it wired to chassis ground. I've attached a basic diagram of what I've built. It uses a +48V SMPS into a JLM audio TREX, which knocks the voltage down to +24V for Neve type projects.
Based on this diagram, can anyone recommend where my chassis grounds need to be (I have pin 1 of the jacks tied to chassis already)?
Any help would be greatly appreciated.
Craig
Craig
