Older api 525 compressor in new 6B lunchbox?
« on: April 19, 2005, 08:26:06 AM »
I just obtained an older api 525C compressor (s/n 2268, Huntington, NY).
I installed it in my 6B lunchbox, but it's not passing signal. Maybe the unit needs to be serviced, but I first wanted to find out if the older units had different pin configurations than the current issues.
I've seen an undated 525 document that did in fact have a different pinout scheme than the current line of modules. Does anyone know if and when they changed this?
I tried calling api, but the head tech is off at the NAB show and the person I spoke to didn't know the answer.
CJ
« Reply #1 on: April 19, 2005, 12:24:19 PM »
PM Paul Wolf. He is a member here.  :thumb:
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
BradAvenson
« Reply #2 on: April 19, 2005, 12:28:49 PM »
Yeah, there was a pinout difference for the compressor and the mic preamps.  At somepoint they changed the compressors to match the mic preamps.  I have the pinouts at the shop if you need them.
BradAvenson
« Reply #3 on: April 19, 2005, 11:27:02 PM »
OK, I found my docs.  It looks like there was a change from the new EQ pinout.  Check out this page for the differences:
http://avensonaudio.com/tech/API/API%20pinout%20change.JPG
API 525 compressor
Started by ChrisA « 1 2 ... 9 10 » The Lab
Last post April 15, 2007, 06:19:58 AM
by Tubemooley
Last post July 02, 2016, 08:01:57 AM
by sharpeleven
Last post August 05, 2018, 07:00:43 PM
by PATAPETER
Last post July 13, 2018, 05:59:49 PM
by Scrappersa
