[BUILD] NU VARIMU 436 build & help thread
bernbrue
Wolfenbüttel - Germany
PCB available now !!!!!
https://groupdiy.com/index.php?topic=53011.msg676707#msg676707
ERRATA:
1) pcb version 1.0 had a minor error in powering the relays, which has been corrected on all boards.  The silkscreen numbering for two resistors was the other way round. This has been corrected as well.
2) The heater wiring of the 12AT7 tube as indicated in the schematic and on the pcb is wrong.  I’ll describe an easy fix later.
You don’t need to do anything at all. These minor errors have been corrected already.
Update 15.12.2018: prototype works fine.. PCBs will be released!! Limited first run!!
https://youtu.be/iFMu9LjsDOM
Boards arrived!! Time to order some Parts
Mainboard and control pcb
https://docs.google.com/spreadsheets/d/12rNmf9cf7eQ6FiIfqCI5pxBC-OZ4AlS7xxHpd1B_OcY/edit?usp=sharing
PSU
https://docs.google.com/spreadsheets/d/1hXxtk70U6ZL8MWpZI4rOfSMPqCykkMMgWcT4OKrs5u4/edit?usp=sharing
universal frontpanel design.  Don´t change the drilling holes, adapt meter cutout to your choice of amperemeter (1mA)
  • NU VARIMU Universal change pdf to fpd.pdf
Here are some voltages from my prototype. My power transformer has the following specs:
Sec 1: 250 VAC, 0,1 A
Sec 2: 24 VAC, 0,5 A
Sec 3:    9 VAC, 2,5 A
B+ is 269 VDC
F+ is 6,3 VDC
Test points:
B= 248V
C= 250V
D= 212V
E= 213V
F= 3,81V
G= 1,15V
H= 1,15V
I= 250V
J= 250V
Measurement were done with DMM minus to star ground, 1mA meter (fsd) and output tx connected (mandatory). Use VR104  for D/ E and VR103 for G/H to get almost identical values. Measure and recalibrate a few times, since almost all values will change when trimming the pots and meter.
Final calibration will be done with a test tone. A detailed description will follow.
Bernd
Okay, now you caught my attention!  :D
Can you give us a little more insight already?
Is this reminiscent of anything (clone, replica) or your complete own design?
And lastly: WHEN will this be available? I want it  ;D
Oh!
Looks like 10 years have passed since the first time something like that apeared around here.
I hope it won t end up like last time!
Thanks Bernbrue.
This will be interesting to see how it differ from the one i reverse engineered.
In my excitement about this project, I've been tinkering with Inkscape and have mocked up a meter insert which more or less reproduces the original Altec design. Fonts aren't perfect, though I'd say it's pretty close. I've sized it to match the Honeywell meters I've got set aside for the project - as far as I can tell, these are the same style & model used on the 436.
Attached as an SVG - hopefully it will be useful to somebody (you'll need to trim and resize to fit what you're working with).
  • Altec meter insert.svg
And a PNG preview of the insert against the reference photo I used, so you can see what I'm talking about!
