Hi all,
This is awesome. Thanks for the schematics, but could you additionally please make some comments about:
1.) The choice of input transformers. There are 1:1 and 1:4 suggestions, under which circumstances would you suggest using those options? (i.e. for use as a line-input tracking/mastering compressor vs a mic-amp or whatever).
2.) The choice of output transformers (even if you just provide, as a suggestion, what you built it with so we have a starting position).
3.) The choice of tubes. On the schematic, the tubes aren't labelled, even though they are for the heater schematic (it'd be great for completeness to add that to the .pdf schematic in the first few posts). I'm curious about the choices, when on one of the "original" threads, the 6ES8 was suggested for the input/gain tube, and the 6CG7 for the output. You guys have clearly suggested other tubes, but is this for reasons of availability, or do we need to modify the other parts for different tube choices?
