USB-B Female 11 pin, input connector for Apogee Quartet
ajes
New member
Hi Group DIY.
I've been looking for at replacement USB input for my apogee quartet.
The device fell to the floor and damaged the USB input, ill try with a repair first, before buying new.
As i can tell its not a standard 5 pin, but this has 11 pins. (something to do with HDMI also being available here)
Anyone has an idea where i might find this connector.?
http://www.apogeedigital.com/products/quartet/specifications
my closest hit is this : http://www.globalsources.com/gsol/I/Micro-USB-connector/p/sm/1046892058.htm#1046892058
Best Anders
Look on digikey. They have nice big pictures of parts. You should be able to identify at least the type. Never heard of an 11 pin USB though.
ajes said:
Hi Group DIY.
were are you located?
You should contact Apogee tech service directly, they have the proper connector.
You can also send them the unit for repair, they don't charge the parts in the repairs, you just pay the time spent reparing the unit  (30 minutes parcels)
Hi.
Thank you for your replays.
I am located in Denmark.
Ill try to figure it out.
