Cleaning out again.... transformers, cable, power supplies
rascalseven
"Tejas"
20 ft Mogami 3172 tube mic cable with 7-pin XLRs
https://flic.kr/p/LQy8Tthttps://www.flickr.com/photos/159032092@N07/
https://flic.kr/p/LQy8Qnhttps://www.flickr.com/photos/159032092@N07/
I wired this up while building some tube mics awhile back and didn't use this one.  New/unused.  Nice, asian XLRs (not quite Neutrik, but reliable and smooth -- like what MXR uses).  $29
Power One 24VDC Power Supplies
https://flic.kr/p/2aAoNhghttps://www.flickr.com/photos/159032092@N07/
These are 1.2 Amp 24VDC power supplies.  Can be used to power Neve style preamps and compressors and anything else needing 24VDC.  I am the original owner of both and used one for a few years to power a Neve 2254-style compresser while the other was used as a supply for bench testing various builds over the years.  Both are perfect.  $15 each.
24v/48v power supply PCBs
https://flic.kr/p/LQy5zzhttps://www.flickr.com/photos/159032092@N07/
I designed these pcbs for use with Neve type mic preamps.  Provide 24vdc and 48vdc from a 24VAC transformer.  Component values screened on the pcbs (will include list too, if you prefer).  Can also be used to do either 24v or 48v only by populating only a given section of the board.  Very useful.  $10 each.
BBC (I think) 600:600 outputs.
BBC outputs 2 by Joel Cameron, on Flickr
Got these years ago and never put them to use.  Nickel laminations.  Heavy, well made.  DCR on yel/blu winding is 25R, red/grn is 37R.  $30 for the pair.
Tamura 600:600 output from Yamaha M1516 console
https://flic.kr/p/27QDdr9https://www.flickr.com/photos/159032092@N07/
$15
Triad JO-series inputs (not sure which one..?)
https://flic.kr/p/27QDdpAhttps://www.flickr.com/photos/159032092@N07/
These look like JO-series Triads to me, but have been painted over (and schematic drawn on the end).  DCR measurements are 78R (pins 1&2) , 82R (pins 2&3), and 5k87 (pins 4&5).  Pin 6 is core/ground connection.  These sounded great in a pair of tube mic preamps and a friend used one for a tube mic output as well (C12 clone) that sounded fantastic too.  $60 for the pair.
Ed Anderson's EA-1166 (Marinair/Neve LO1166 clone) output transformers:
https://flic.kr/p/29aTG62https://www.flickr.com/photos/159032092@N07/
These are a perfect pair of Ed Anderson's Neve/Marinair LO1166 output transformer clones that Hairball used to sell (now they only do the small 500-series types, I believe).  These were used for prototyping, connected series:series (1:1.73 ratio), the way Neve used them in almost every class-A module output.  $85 for the pair.
PM me with questions, thanks.
JC
Just modified original post with lower price for outputs, and added a pair of EA-10468 Marinair/Neve style mic inputs as well.
Thanks for looking!
JC
