5v333
does anybody know the meaning of the combined cathode bias and positive fixed bias in the 12au7 tubes of the pultec?
i had an idea what could be going on...
when you have a higher Vg point for high input swings, you might end up with a loadline/Qpoint that has less stellar distortion signatures.
perhaps this technique gives you both?
first cathode bias a high enough grid voltage so you can maintain class a at high input signals.
then put some positive voltage through the grid so that your cathode voltage rises in reference to the plate voltage. and by doing so your platevoltage woking point finds a lower point with lower thd signatures.
