Double ear eyelets
lampas
Does someone know, where to buy a double ear eyelets, similar the ones in the M49 microphone ?
https://fr.aliexpress.com/item/1000pcs-3-2-Inserts-Plug-Spring-Terminal-PCB-Solder-lug-type-thickness-0-3mm-Copper-washer/32709471236.html?spm=a2g0w.10010108.1000014.4.443bc76eVvhbS1&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.110450.000000000000000&scm_id=1007.13338.110450.000000000000000&scm-url=1007.13338.110450.000000000000000&pvid=5edb8c02-ac8c-4c57-a210-8c7aa9d1fa4b
Where are you located?
There is a shop in Switzerland but the shipping is really expensive to other countries...
I would also like to buy some stuff from there but the shipping cost are holding me back.
http://shop.griederbauteile.ch/product_info.php?cPath=1360_1361&products_id=9673
I used "double pins" from Aliexpress and brass rivets from Ebay. It was easy with grommet tool. I drilled the inside hole of "double pins" to increase it to fit the grommets nicely.
https://www.aliexpress.com/item/1000pcs-2-2-Inserts-Plug-Spring-Terminal-PCB-Solder-lug-type-thickness-0-3mm-Copper-washer/32709100694.html?spm=a2g0s.9042311.0.0.6ad94c4dk7Qcx9
Tool for 2mm eyelets
https://www.ebay.com/itm/Leather-Crafts-Eyelet-Grommet-Setter-Tools-Anvil-Die-Set-Punch-Tool-1-5mm-40mm/332529819702?hash=item4d6c526036:m:mOALgZq4gSqfv9XM21Vd4Hw
2mm inside dia x 4mm lenght
https://www.ebay.com/itm/Solid-Brass-Eyelets-for-Leather-Craft-Grommet-Banner-1-5mm-2mm-2-5mm-3mm-3-5mm/332663879511?var=541790248368&hash=item4d744ff757:g:WzYAAOSwenlbCLvm&varId=541790248368&redirect=mobile
Vac11 said:
I used "double pins" from Aliexpress and bras rivet from Ebay. It was easy with grommet tool.
https://www.ebay.com/itm/Copper-Brass-Vias-Rivet-Nuts-Through-Hole-Rivets-Hollow-Grommets-M2-3-M2-5-M3/172325490121?var=471144053545&hash=item281f664dc9:m:m9eJoXDwwYQxw8SeivnNGjw
Thanks for the info.
Otherwise very nice board. Is this plexyglass ? Did you cut it yourself ? Thanks.
Thanks. It is FR4 material (standard PCB 1.6 mm thick board). I designed this board for Oliver Archuts M49 point to point build and Banzai M49 body... Boards are from chinese PCB manufakture. Let me know if you want some pcs, I have about 8 pcs in stock...
I also have transformer boards, rubber parts (Mobys xformers compatiable) and capsule boards...
There was some interest. Boards has been sent to everyone who contacted me. Thank you.
To Lampas: Your PM box is full, I have contacted you on your email, but no response.... Did you receive the boards?
Everything OK  :)
It appear that something is wrong with this board ... I could count 10 messages in my Inbox but the system count 50 and 100% even If I delete a few ones ...
Thanks again!
abbey road d enfer said:
Do you use your provider's webmail or a client app such as Outlook or Thunderbird?
No, just internal (from this board) messaging system ...
Regards.
Ok, all my boards sold. Thank you. Btw. here is final result....
