Would making a filter from common and diferential mode chokes, as used in mains filters, combined with large value electrolytic caps be usefull for filtering 50/100hz , as well as harmonics of, in a regulated LT supply output?
Theres a number of times Ive gotten noise down to mostly resistor noise ,but a small residual low frequency component is nagging in the backround and it comes from my heater supply ,a small ,maybe 30db additional reduction would render this noise totally masked by circuit noise .
So lets say, two common mode chokes in series ,large caps 1000uf or more ,across the sections , then two diferential mode chokes in series with each output followed by another large cap to ground off each leg .These chokes are normally used with small caps ,will they work as effective filters at low frequencies with large electrolytics ?
Would there be a benefit to applying an extra filter stage post regulator ?
In most of my preamps resistance noise already dominates hum by a large factor , but its just to remove that final remenant of the 50 hz thats very difficult . In normal usage this small hum is buried anyway , but in the case of very low input level from the mic it is there in the backround .
Just in case someone mentions grounding ,thats all as good as can be ,power and signal are on different chassis also and Ht hum is in the uV range.
