So just made a few small changes , including rearranging the final decoupling cap in the ht line ,and moving the choke to directly in series with the anode load resistor . Hum is totally gone from the output even at full bass boost no trace at all.
Will the inductive reactance of the choke in the anode circuit help present a higher anode load to the pentode ?
Will this increase the open loop gain of the stage ,as I think I'm seeing a slightly higher range on the boost controls after the changover.
For now Ive run the screen off the simple series resistor ,tapped off before the choke , what happens if I tap the screen voltage after the choke and before the anode load resistor ,now my screen will be fed a portion of the output signal ,it starts to look a bit like UL connection , if I disconnect the screen decoupling cap can I expect a change in the open loop gain and impedence due to feedback ? How will the LF constants of the coupling and decoupling components play out ?
Anytime I vary the bias point of the stage I see the screen volts trail along behind, in either positive or negative direction following the anode ,also after switch on settling time is minutes ,no major problem in itself, but in the event of transient overload I wonder how does a rock solid reference voltage for the screen play out vs a supply that allows degrees of negative feedback to anode, or could I even have a switching arrangement ,to give three posibilities ,regulator fed , conventional series resistor bypassed to cathode or UL with screen decoupling removed .
I'll sketch out my ideas on paper and post them once I grab a coffee , for claritys sake.
Thanks to Merlin also, I found the valve tracer circuit on his excellent Valvewizard.co.uk site , it has a very simple but effective screen regulator ,just a hand full of components , specifically designed for small signal pentodes , I think I might give it a try .The valve tracer is such a neat machine , I think thats definately going onto the project list as well , the simplicity is remarkable . I can see how it wont make a commercial design as you need to know what your doing with the patch cables or your going to fuse the unit out and probably burn out/damage tubes. Maybe two seperate 9ba sockets ,one for ef86's and one for dual triodes might simplify the patch bay , at the expence of universality of usage by having all electrodes patchable . Seeing as I have an Arb Gen with usb upload of waveform ,can I generate my ramp voltage on that and simplify the build of the unit an order of magnitude simpler ?
Theres a few scenarios in the drawing , I wonder if someone could explain better the implications of the different setups . For now 1Hy will do and it makes calculations easy ,I know its a low value . I did find a way of making a dual bobbin anode load choke by getting two identical small transformers of the usual kind found in old domestic equipment (with the clear plastic that has seperately removable pri/sec half bobbins) . By combining two primary sections which have a dc resistance of a couple of thousand ohms each on the same laminations E/I stacked and gapped, I can get somewhere between 50-100Hy ,but these are very small transformers and probably wont handle much current . Still looks like a very easy and cheap way to create a multi section anode load choke , If you dual wound each half bobbin to get four seperate pi sections you could probably do very well in terms of frequency responce ,swapping out the plain silicon steel lams for something more exotic might get you hundreds of Hy. Its an interesting experiment into Tab/Siemens V style pres and output stages , that costs nothing . Would it be possible to wind an anode choke in such a way that it acts as a centre tapped load to a push pull pair ,then capacitor couple both anodes to a centre tapped mumetal signal transformer?
Sorry about the long and winding post ,any ideas at all that spring to mind graciousy recieved .
