Phantom power
ilfungo
ITALY
Hi
can someone tell me if this connection is correct?
what is the function of 100uf cap to ground and 820r resistor?
thanks!
I need to insert also the 1uf capS?
ilfungo said:
Hi
thanks!
To ramp up the phantom voltage
Yes, you need caps to block the DC phantom voltage from the mic input
questionable, your mic image is a dynamic capsule so it does not need phantom. If the 1uf caps are polarized the positive side needs to face the phantom voltage.
