we set the idle current and offset voltage , but there are two more trimmers for setting the power threshold but nothing in the service manual on how to adjust these last two pots,
maybe run a signal into a dummy load and adjust for 70 watts per side?
it would be easier to set them by base voltage, maybe 0.4 volts like we see on a working unit?
or calculate power with 45 volt rails, how much current will flow through the 0.2 ohm sensing resistors , how much voltage will be transmitted to the base by addition to the voltage already on the bases via the trimmers? ie 70 watts / 90 volts = 0.78 amps into the 0.2 ohms = 0.155 volts added to 0.40 volts = 0.555 = transistors turn on?
thanks for any help!
