Dimitree
- Joined
- Jul 26, 2011
- Messages
- 118
hello everyone
during my work lunch break, I like to do some audio DIY,
so since I got a V1401 chip (clone of the AL1401 ADAT transmitter) I'd like to build a 8 channel digital converter (with line inputs) that I can use with my Focusrite Scarlett 18i6 interface that has got an ADAT input.
I know I could just buy one if I'd need, but I really want to build it, that's my hobby
I already successfully built a DAC from scratch (schematic, smt PCB) around PCM5122, also I have large experience with building analog/digital synthesizers, but I still don't know much about ADAT and digital audio transmission.
So first I'm trying to understand if it can be done like this:
4x PCM4220 (or CS5381) ADCs connected to the AL1401, one of them set as master, the other three as slave.
Master clock generated on the board (no externarl word clock input needed), using a pair of low jitter TXOs, manually switched depending on the desidered sample rate.
I'm wondering if this master clock can be supplied to both the ADCs and the ADAT chip, and if that would create problems since on the Focusrite interface, you should set the sample rate on the software (so the master must be the Focusrite?).
many thanks to all!
many thanks to all!
