rockinrob86
Rubber for pinch rollers?
« on: October 09, 2018, 09:04:50 AM »
What type(s) of rubber are typically used for pinch rollers?
I have an idea for making some of these and am looking for a rubber hose material I could use
madswitcher
Re: Rubber for pinch rollers?
« Reply #1 on: October 11, 2018, 02:30:06 PM »
Hi Rockinrob,
I would advise against trying to make your own pinch rollers: they are precision parts and have to be made to tight tolerances to avoid wow and flutter on tape machines.  That's why they are so expensive.   The outer cover is a specialised material that is moulded onto a core - usually brass - and then finished off by machining on a lathe.
Kind regards
Mike
rockinrob86
« Reply #2 on: October 12, 2018, 09:05:14 AM »
I understand this - however, we're on a DIY forum, and I am one of the many on here who responds to "it's too hard, I don't recommend doing it" with "It can't be that hard, I'm sure I can figure something out."
Sometimes I do, sometimes I don't.  I know nothing about rubber formula names though, so that's the info I need.
I've done some googling, but am unsure how the specific rubbers characteristics relate to this application.
This will not be for pro audio or home audio use, and I really want to figure out how to build my own.
gyraf
« Reply #3 on: October 12, 2018, 09:45:30 AM »
At least some are made of PU
Cast to approximate shape, then vulkanized/hardened, and lapped/sanded into shape
Ask someone that knows paper-handling rollers for printers and plotters - and look for spares for those...
Jakob E.
mjrippe
« Reply #4 on: October 12, 2018, 02:30:13 PM »
PU = polyurethane?
Also, try contacting Shane at https://echofix.com/  He makes replacement rollers for Roland Space Echoes and is a super helpful and friendly person.
madswitcher
« Reply #5 on: October 13, 2018, 06:37:44 AM »
Yes, Athan uses Polyurethane on his rollers.
I have used his stuff for years and he is very helpful.  I am not sure if he will supply the raw material, but its worth a try.
Mike
Last post February 16, 2005, 10:42:22 PM
by SSLtech
Last post January 21, 2011, 02:20:47 PM
by madswitcher
Last post June 23, 2015, 10:54:18 PM
by Gold
Last post June 11, 2013, 06:49:24 PM
by buildafriend
